Herbie235
Mar 30, 2020Follower
ReadyNAS NV+ V2 Firmware SMB 2
A question for the forum, following a recent PC upgrade to the latest major Win10 release, Win10 no longer permits a connection to the shared folders of the ReadyNAS NV+ V2 with an error message stat...
Sandshark
Mar 30, 2020Sensei
While a new NAS is likely a good forward plan, I believe that SMB1, used only on a local home network that is properly secured (no holes punched in the firewall), does not bear the level of risk Microsoft would have you believe. I'm sure protection from lawsuits is a big part of the reason for the harsh wording.
- StephenBMar 31, 2020Guru - Experienced User
I agree, though you do need to enable it with both Windows 10 and Catalina MacOS (not sure how to do that with MacOS).
FWIW, the risks are much higher in enterprises. Microsoft accelerated their deprecation of SMB 1 in response to WannaCry - which did exploit the security weaknesses in the protocol.
