Yeahh
Apr 22, 2013Aspirant
Readynas NV+ ver 1 equivalent ?
I currently have an NV+ ver 1 which has just died on me. So I have two needs. 1). What would be the new equivalent model? 2). How do I get my data from the old unit to the new one? I was hoping I ...
Apr 22, 2013Guru - Experienced User
In the new line, the equivalent model would be the RN104. The RN314, RN514 are higher performance business versions.
You could also consider a Pro-4, as they are being discounted as they roll over to the new line. It would have a 5 year warranty, much higher performance than your NV+, and a similar GUI.
Either way, you can't migrate your disks. There is a post here that gives you some options, but it assumes a fair amount of facility with linux: http://home.bott.ca/webserver/?p=306.
Do you have a backup?
