ccc1997's avatar
ccc1997
ReadyNas Pro 6 + Which Hard Disks?
I prices are getting low enough that I can finally get a RNP6. I just missed a really good deal on NewEgg that I read about in the forums; if it comes back i will grab one. I expect the prices to drop as this is nearing the lifecycle for this product line. So, the question, which disks to get? Are these good choices? Just looking at the specs they have the longest warranty with the most cache, and a 6Gb/s interface.
Western Digital WD RED WD30EFRX 3 TB 6Gb/s 64 MB Yes 3
or
Seagate Constellation ST33000650NS 3 TB 6Gb/s 64 MB Yes 5 Must be used with 4.2.16 or newer firmware.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Both of these require RAIDiator 4.2.16 or newer. If you get a NAS with older firmware, put one disk in, update to latest firmware, verify update completed then do a factory default with all disks in place.
    The SeaGate disk is an enterprise disk and an excellent choice if your budget permits.
    If on a smaller budget the WD RED which is designed for NAS use in 1-5 bay systems (though should work fine in a 6-bay and it's a qualified disk) is a good choice.
  • The Seagate disk states that a specific firmware needs to be used; can I upgrade the firmware (if needed now or in future) easily while installed into a RNP?
  • StephenB's avatar
    No. You need to do that on a PC (or an x86 Mac, using the Seagate boot CD).
    mdgm-ntgr
    The compatibility list talks about NAS firmware requirements for that disk, not disk firmware. In 4.2.16 support for 3TB disks was added. Yes you would need to have at least one 3TB disk installed to update the firmware.
ProSupport for Business
