McRob1
Mar 22, 2020Luminary
Readynas Pro 6 Readycloud Fails after Loading Firmware 6.10.3
Installed the latest OS version 6.10.3 on my Readynas Pro 6. Now I can no longer connect to Readycloud. When I go to the cloud tab and attempt to turn on the service I get an error message. See at...
McRob1
Mar 23, 2020Luminary
Tried OS-Reinstall as suggested.
No change. I am still not able to get Readycloud process to start as before.
Any other ideas?
Thanks for your input.
McRob1
Mar 24, 2020Luminary
After hearing no response I did a factory reset.
After completing the factory reset on the NAS I was able to get the readycloud turned on without the error message.
I was still not able to connect locally to the NAS using readycloud.
Even when I turned readycloud off the NAS still showed up as an active NAS in readycloud.
I was able to disconnect the NAS using the web based readycloud.
After many tries I was able to get the NAS connected again.
Now the NAS is doing a syncronization that will probably continue for the next day or so.
Then I get to copy all the data I backed up, back onto the NAS.
I wish Netgear could develop more stable software.
