oshae's avatar
oshae
Tutor
Mar 04, 2019
ReadyNAS Pro 6 with 8TB WD Reds
Curious if anyone with a ReadyNAS Pro 6 (Upgraded to OS6), is running WD 8TB Reds?   I'm planning to upgrade my 3TBs over the next few months. Wondering if there are any issues? I did read someth...
  • Marc_V's avatar
    Mar 05, 2019
    Hi oshae
    The 8TB WD Reds WD80EFAX should work fine as they are NAS purposed drives. Pro 6 on OS 6 will support this capacity or even higher. Just make sure you get the drive without the 3.3v Pin
    The issue with the 3.3v is that Pin 3 does not have any connection so the drive may or may not spin up that is why drives without that feature is not advised.
    Hope this helps!
    Regards
ProSupport for Business
