oshae
Mar 04, 2019Tutor
ReadyNAS Pro 6 with 8TB WD Reds
Curious if anyone with a ReadyNAS Pro 6 (Upgraded to OS6), is running WD 8TB Reds?
I'm planning to upgrade my 3TBs over the next few months. Wondering if there are any issues? I did read someth...
- Mar 05, 2019
Hi oshae
The 8TB WD Reds WD80EFAX should work fine as they are NAS purposed drives. Pro 6 on OS 6 will support this capacity or even higher. Just make sure you get the drive without the 3.3v Pin
The issue with the 3.3v is that Pin 3 does not have any connection so the drive may or may not spin up that is why drives without that feature is not advised.
Hope this helps!
Regards
oshae
Mar 06, 2019Tutor
Yes defintiely helpful, thank you! WD80EFAX is what I'm planning to get.
Curious though for the future. Is it the backplane, or the power supply in the Pro 6 that is the issue? Would a power supply upgrade in the Pro 6 fix the issue? In the event that down the line, the only thing available are drives with the 3.3V pin?
Or is the messages essentially, if/when this start happening it's time for a NAS upgrade?
Mar 07, 2019Guru - Experienced User
It is possible to isolate the pin on the drive with some Kapton (polymide) tape.
If you google "pwdis kapton" and/or "pwdis polymide" you'll see several guides.
- SandsharkMar 08, 2019Sensei
It's the backplane that's the issue, But that pin and all 3.3V pins are already floating on a Pro 6, which is what the tape will do. I do not know of any desktop ReadyNAS that has a connection to the 3.3V pins on the SATA backplane.
- StephenBMar 08, 2019Guru - Experienced User
I agree that all the tape does is make sure the pin is floating.
So if the pin is floating in the backplane,the tape isn't needed.
