Vertgo's avatar
Vertgo
Readynas pro 6
I have a readynas 6 pro that had RAIDiator-x86 4.2.27. I had it dual redundant but the motherboard or something recently died and now it does nothing if I hit the power button. If I want my data off of it which piece of hardware can I buy?
  • StephenB's avatar
    If you do go with a new 52x or 62x ReadyNAS, then the procedure to offload your data is here: https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86?cid=wmt_netgear_organic
    You might want to check the warranty status (hardware warranty is 5 years).
    The power supply is a more likely failure than the system board - and the PSU can be replaced.  If you search the forum, you will find quite a bit of material on that.
    One possibility is to get a new NAS, and then try to repair the Pro - if you succeed you can use it for backup of the new NAS.
  • Hi guys,
    I've actually been a readynas user since before the netgear acquisition with a 4 disk drive bay (that died a long time ago). I'm certain i'm out of warranty, but yeah i'll try to replace the psu and then maybe update the whole nas. If I do the migration will it just be some metadata changes or will it have to rewrite all the stripes?
    • StephenB's avatar
      The x86 OS6 NAS can mount the pro volume read-only, but that is only to allow you to copy off the data.
      After that it's a complete wipe/restripe.
      It still uses mdadm raid, but the file system is BTRFS, not EXT.  There are other differences in the data volume setup - for instance, apps are installed to the data volume instead of the OS partition.
      BTW It is possible to switch your Pro-6 over to OS6 also (when/if you get it working agin).
    • Sandshark's avatar
      Sandshark
      Sensei
      If you have a spare ATX supply lying around, or can "borrow" one from a PC, you can use that externally to verify it's the PSU before replacing or just to power it while recovering the data.
ProSupport for Business
