sjshumaker
May 04, 2018Follower
ReadyNAS Pro Business Upgrades
Recently acquired a ReadyNAS Pro Business model (RNDP6350-100) with 6x750GB HDDs in excellent shape for almost free. Original owner added a second RAM stick to give it 3MB total but did no otehr up...
May 05, 2018Guru - Experienced User
There is no known disk size limit with OS-6, and the largest available drives (12 TB at the moment) will work in your NAS.
Currently shipping OS6 NAS start at 2 GB, so you might actually have enough RAM for now. But your system will support up to 2x4GB.
I'll let others speak to the possibilities on CPU upgrades. I will say that there's not much benefit in storage performance, but there would be a benefit if you want to run a CPU-intensive app such as plex.
If one of your goals is to maximize storage performance, then you should consider using the SSD metadata tiering feature. That will require using 2 slots for SSD disks, so you'd need to upgrade at least two mechanical disks to keep the same amount of storage (assuming single redundancy). I suggest using SSDs that are intended for NAS/server workloads (the EVO 860 Pro being one possibility).
Musso
May 05, 2018Aspirant
Have pretty much the same ReadyNAS Pro Business Edition (as well as a 2100 v1 and v2) and was looking into getting memory upgrades for these units. I can't seem to find any table or upgrade compatibilty list of known working modules - seem to default to the netgear main page these days (although I do appreciate that these are unsupported units these days). Can anyone point me to an upgrade specs for the 2 x 4GB memory modules.
KInd regards
Musso
- SandsharkMay 05, 2018Sensei
For all 6-bay Pro models, you need PC2-6400 low density (2Rx8) memory, 4GB max per slot. 4GB DIMMs carry a premium price because only 64-bit operating systems (which were not in common use except for servers when PC2 memory was the best available) can use more than 4GB. High density (2Rx4) will not work.
- StephenBMay 06, 2018Guru - Experienced User
Very true, and DDR2 is getting harder to find.
I upgraded my pro-6 some years ago with Patriot Memory ( https://www.amazon.com/gp/product/B004ZG20C6/ ). That particular option is ridiculously priced now.
- MussoMay 07, 2018Aspirant
I've currently got the following spec in the ReadyNAS Business Edition and was thinking about upgrading the CPU. Found elsewhere in the forum that I would need the BIOS updating first then could upgrade to OS6. Any recommendations for the CPU? Some people seem to have fitted a Xeon in there which was a surprise! but willing to go up to whatever is suitable for cooling/power etc.
Product Version: 10/03/2008 FLAME6-MB V1.6
BIOS Version: 080014
BIOS Date: 10/03/2008CPU: Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
CPU Family: 6
Model: 21Stepping: 0
Model Name: Genuine Intel(R) processor 1.06GHz
CPU MHz: 1066.632
Cache size: 256 KB-------------------------------------------------------------------------------
KInd regards
Musso
- MussoMay 06, 2018Aspirant
Many thanks for the info, I've ordered some today :-)
Kind regards
Musso
