the_scotsman1
May 07, 2014Aspirant
Readynas Pro Business Volume dead
Except for the occasional hang while scrubbing the disk, my Readynas Pro Business Edition has been working fine for several years.
Radiator 4.2.25
4 x 2GB WD RE4 HDD
X-Raid 2
All that changed recently when every backup failed.
When I wend to check the Readynas via Frontview I found that ALL HDDs were dead as was the volume. Once I rebooted the Readynas the disk icon at the bottom was now green (no popup) but the volume is still dead.
I never received any emails showing HDD errors, or any type of error other than backup failures.
I don't think the backup failure is the root cause of the issue.
Interesting thing is that I can still access some(?) of the shares some of the time(?) via a PC - at least right now I can but not sure how long that will last.
I'm not panicking too bad as most, if not all, of my critical data is backed up to a PRO2 but there are some shares that were not due to the limited space on the PRO2 - I'm working on backing those up to a new RN102 right now.
I do want to figure out where the failure has occurred. Is it the HDDs? Is it a s/w bug? Is it a NAS h/w issue?
Any tip on non-destructively debugging this would be we welcomed.
Thanks
Paul
Radiator 4.2.25
4 x 2GB WD RE4 HDD
X-Raid 2
Thanks
Paul
- mdgm-ntgrNETGEAR Employee RetiredContact support. You can do this online. See support.netgear.com
- StephenBGuru - Experienced UserObviously don't debug (and avoid restarts/reboots) until after the backup finishes. I agree that contacting support the best option.
- the_scotsman1AspirantI'll contact support later today. Great news is that the unit is still under warranty :-)
Then support is certainly the way to go. Complete the backups before going into their tech support mode though.the_scotsman wrote: I'll contact support later today. Great news is that the unit is still under warranty :-) - the_scotsman1AspirantI'm going through everything I have access to and ensuring I have a backup and that the backup is complete.
Probably tomorrow before I will complete this.
Thanks
Paul
