mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
One additional info (don't know if it helps): 15 Minutes ago i opened the case directly after shutdown and the cpu cooler seemed to be rather cold (didn't measure it but comparing it to body temparture i would assume it was around 35 degree) although frontview reported about 61 degree before shutdown?! May there be a contact issue between cpu and cooler? Already checked the screws of the cooler but all are fixed as they should...
