mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
chirpa
Jul 28, 2010Luminary
With the side panel off, is the CPU fan a 4-wire plug going to the mainboard, or a 3-wire plug going to the daughter board near the back? http://www.readynas.com/?p=1912
