mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
beisser1
Jul 29, 2010Tutor
chirpa he probably has the same issue as i did on my pro. reverting to 4.2.11 should instantly fix that. newer firmwares report cpu temp 5 degrees too high which generates these warnings.
