mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Jul 29, 2010Aspirant
Since install of T11 CPU Temp went 5-6 degrees down. Seems that beisser was right. Thanks for fixing, chirpa!!!
