mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Jul 29, 2010Aspirant
Sorry wrong info: the at first sight recognized lower temperature may have been caused by the reboot after upgrading to T11. Now after reading and writing from/to the readynas temp1 is at 64 degrees again and the cpu fan maxes out at around 1500 rpm...
