mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
bollar
Jul 30, 2010Aspirant
I am still having this issue occasionally with T11:
Temperature sensor 1 reports out of normal range [expected range: 0-65C/32-149F, current: 66.0C/150.8F].
