mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
bollar
Jul 30, 2010Aspirant
mattseattle wrote: He said ---> Can you try 4.2.11
He also said: Please try T11, viewtopic.php?f=51&t=43739
I'm confirming that I see the same issue as the OP with T11.
