mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Aug 01, 2010Aspirant
@chirpa: Would like to do the test with 4.2.11, but please give me any advice if i have to care about anything before/while downgrading. Thanks again for your help!
