mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Aug 03, 2010Aspirant
@Chirpa:
I just asked a friend of mine who also owns a readynas pro with 4.2.13. At the moment i spoke to him his cpu fan was rotating at 2136 rpm!
But why is the cpu fan in my readynas pro maxing out at around 1500 rpm even if the cpu temperature runs out of specs?
Any idea? I really would like to avoid any kind of hardware damage because of too high cpu temperature!
Thanks in advance for help!
TheMule!
TheMule!
