mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
Jedi_Knight
Aug 03, 2010Tutor
It could be CPU FAN it self that can't go more than 1500RPM. is there anyway could you take a picture of the CPU FAN?
