mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Aug 03, 2010Aspirant
I don't think that this is the reason for the issue, because during startup the cpu fan is much louder and raidar shows it running at a minimum of 2000 rpm during boot...
