mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
snipes
Aug 04, 2010Aspirant
Add me to the list of affected units. I never had this warning before I upgraded to 4.2.12-T32 from 4.2.11. Since then I've tried various 4.2.12 and 4.2.13 releases. All of them raise this warning about once a week for me.
