mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Aug 05, 2010Aspirant
So any advice what to do? I'm scared about the fact that the cpu is permanently running near or above spec limit. What does it mean in regards of it's lifetime? Whill it be shortened?
So please give us any advice what to do or please give us some kind of information if you're just in the process of evaluating this issue.
Once again: Thanks in advance!
