mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
Jedi_Knight
Aug 06, 2010Tutor
Thanks for the system log. it looks like system temperature and not CPU.
Temp 1 is for System and Temp 2 is for CPU.
