mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
beisser1
Aug 08, 2010Tutor
Jedi Knight wrote: Thanks for the system log. it looks like system temperature and not CPU.
Temp 1 is for System and Temp 2 is for CPU.
maybe temp 1 and temp 2 should/can be renamed to reflect this?
does that mean the system is allowed to get up to 85°C in the ultra? hard to believe :)
this sounds more like a limit for cpu-temperature on the atom cpu :)
