mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
damon1
Aug 10, 2010Aspirant
I just upgraded to 4.2.13 and am now getting temp errors when I wasn't before.
Temperature sensor 1 reports out of normal range [expected range: 0-65C/32-149F, current: 66.0C/150.8F].
My fan speed is 1371rpm for the sys. 2083rpm for the CPU
-----I re-calibrated the fan and speeds and temps are about the same ----
