mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Aug 12, 2010Aspirant
Sorry for mixing things up regarding temp1 and temp2 (would be great to give them real names as already suggested)! I just edited the subject correctly.
But the issue still exists and i'm not alone as reading the posts from other users.
Today i got 4 new messages telling me once again that the system temp ran out of spec though the pro stands totally free to all sides and i didn't even use it the time the messages popped up!
Calibrating the system fan doesn't help either!
So does anyone has a clue of what's going on here? Does it really run out of spec or is it just a wrong indication within frontview?
TheMule!
TheMule!
