mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
rvanider
Aug 13, 2010Aspirant
I have been getting similar behaviour since 4.2.10. Temp1 runs up to 65C and the fan will kick up to 2000+ to bring it down after the sensor warning. Calibration does not seem to correct the issue but rather generates even more alerts. When the fan kicks in at full speed (is 2000 the top speed?) the temp drops to 53C but the fan will eventually drop to about 1000 and the temperature will slowly rise until the alert fires again.
