mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Aug 13, 2010Aspirant
What rvanider describes exactly seems exactly to match with my experience.
So for me it seems that the system fan's low threshold is set incorrectly while being calibrated or that the temperature curve is not beeing set correctly...
