mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mattseattle
Aug 13, 2010Aspirant
Agreed... calibration has no bearing on my temp warnings. It will ramp the fan up for a few minutes but then throttles back down to about 800 - 900 rpm and the temp will climb back up.
