mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
hobbes487
Aug 25, 2010Guide
Any new info on a solution to this problem? I am seeing the same thing with my Pro Pioneer with 4.2.13
