mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
spiderman1
Aug 26, 2010Guide
I believe that something has to be done about this. This was never the case with Raidiator 4.2.12.
I am always getting
my FAN SYS kicks in immediately and will run at 1328 RPM to lower temperatures.
Any ideas?
I am always getting
Temperature sensor 1 reports out of normal range [expected range: 0-65C/32-149F, current: 66.0C/150.8F].. Yes,
Any ideas?
