mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
ahpsi1
Aug 26, 2010Tutor
Hmm, haven't seen an alert yet and don't remember temps/rpm's from before moving to 4.2.13 but here are mine:
System is in a server room where ambient (at the top of the rack) does not exceed 79 F.
Fan SYS 1520 RPM OK
Fan CPU 1394 RPM OK
Temp 1 50 C / 122 F [Normal 0-65 C / 32-149 F] OK
Temp 2 25 C / 77 F [Normal 0-60 C / 32-140 F] OK
