mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
NilsTOP
Sep 05, 2010Aspirant
Hello @all,
yes there seems to be a problem. I have 2 Readynas Pro.
One - the older one - now has temp (CPU) errors and the fan will not go over 1500 rpm.
The newer one works fine ...
Maybe this information helps you to track down the problem.
Nils
Nils
