mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
NilsTOP
Sep 08, 2010Aspirant
Well, I have a QNAP System too :-) normally I use it as a backup for the Readynas ...
Nils
Nils
