mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
Cecilia
Sep 09, 2010Aspirant
Hi, just want to add a "me too" here...I upgraded to .13 a couple of weeks ago and noticed my office get *really* noisy, with way more than the usual fan noise. At first I figured it was because we got a few abnormally hot days here in SF...but I got no error messages. Then the temperature plummeted to its normal 60 degree summer and the fans still kept going....
This is what I'm seeing right now, in case anyone's interested:
Fan SYS 937 RPM
Fan CPU 3590 RPM
Temp 1 48 C / 118 F [Normal 0-65 C / 32-149 F]
Temp 2 31.5 C / 88 F [Normal 0-60 C / 32-140 F]
Fan SYS 937 RPM
Fan CPU 3590 RPM
