mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
yubyub
Sep 10, 2010Aspirant
Netgear,
Any response here?
Is this a known issue?
We need to hear from you.
Any response here?
