mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Sep 15, 2010Aspirant
i would like to add a "me to" to this list.
I am currently working on a support ticket with this problem in it (as well as some other problems relating to 4.2.13 upgrades) and will be sending some logs perhaps that will help the in house testing.
