mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Sep 16, 2010Aspirant
@Chirpa: Thanks for giving us some status info! Do you eventually need our serial numbers if the issue maybe limited to certain production batches?
