mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mdgm-ntgr
Sep 16, 2010NETGEAR Employee Retired
Isn't your support case (if you have one) tied to the NAS that you registered?
Anyway since you've sent your logs in to chirpa he would already have your serial number as it would be in there.
