mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Sep 16, 2010Aspirant
@mdgm:
you mixed things up: lisster has a support case open, not me.
My feeling is that the issue depends on certain production batches because not all readynas pro seem to be effected: A friend of mine also own a pro but without any issue and if you have a look at the posting of NilsTOP in this thread he tells about owning 2 pros of which only one has shown this issue.
So collecting serial numbers may help to find a pattern if it's batch production dependent. Just an idea...
