mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Sep 16, 2010Aspirant
chirpa wrote: If you have an open support ticket, please share the case number, so we can reference that during our testing.
thanks chirpa, my Case is #13105855
I just sent logfiles to Arthur who is handling the case and updated the ticket with a very long explanation i won't post here since it;s a book heh.
hope i can help with pinpointing the issue
