mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Sep 16, 2010Aspirant
@mule:
If it's certain batches i must be the most unlucky person in the world. I have 3 Pro's (apr 2009 from newegg in the USA, jun 2009 from a dealer in Holland Europe, and another aug 28 from newegg in the USA) and all 3 have the exact same issue :P
They also have another weird issue with reading speeds which also happened after i upgraded to 4.2.13 on each of them.
Lets hope they figure out what it is soon :P
