mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mule
Sep 16, 2010Aspirant
Ok, speculationg from my side ends now. I'll wait and sit down until netgear comes out with infos and hopefully a solution (soon).
