mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
spiderman1
Sep 18, 2010Guide
An update.
It has now been 3 weeks since my TEMP 1 sensor problems.
Ambient temperatures are now within the 20C-27C range in my house and as a result the PRO is no longer exhibiting such problems. The problems for me started
when ambient temperatures were within the 31C-36C range and humidity at 85%.
The problem seems to be related to 4.2.13 as I never had problems before this version.
Latest readings (20C-30C, humidity at 50%)
Disk 1 Seagate ST31000528AS 931 GB , 34 C / 93 F , Write-cache ON OK
Disk 2 Seagate ST31000528AS 931 GB , 35 C / 95 F , Write-cache ON OK
Disk 3 Seagate ST31000528AS 931 GB , 34 C / 93 F , Write-cache ON OK
Disk 4 Seagate ST31000528AS 931 GB , 35 C / 95 F , Write-cache ON OK
Disk 5 Seagate ST31000528AS 931 GB , 36 C / 96 F , Write-cache ON OK
Disk 6 Seagate ST31000528AS 931 GB , 35 C / 95 F , Write-cache ON OK
Fan SYS 912 RPM OK
Fan CPU 1896 RPM OK
Temp 1 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp 2 26.5 C / 79 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS RS 1200 LCD, Battery charge: 100%, 260 minutes OK
