mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Sep 18, 2010Aspirant
small update from me to.
After installing a cooler master fan it was great for 2 days, rpm were 1900 for my case fan, stayed at a nice 55-57c.
Then suddenly at 22:06pm and at 79f in the house with AC on it started overheating to 66c :P
After about a minute it sped up and now were down to 57 again..i wasn't even using it most of the nite.
Then about 8 min later same thing, over heat, speed up, cool down.
When it started going back up i hit recalibrate fan and its been good for a day again... so weird
