mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
the_evaluator
Sep 19, 2010Aspirant
i'm just chiming in on this, i don't have a case open yet, but i've seen the same behavior with my Pro, i'm pretty sure since 4.12. my cpu fan is running at 2000 RPM, and the main at 1000. my main temp hovers at about 141 pretty much all the time, and can easily spike into alerts depending on conditions. i'm running a pro with 4.2.12 final with only 4 1tb samsung HJ's.
i'd be happy to replace the fan with something, perhaps different resistors to get RPM's- if only Netgear would chime in. this threads been going for months, mostly ignored.
