mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
reelmccoy
Sep 19, 2010Aspirant
Installed 4.2.11 on both Pro Biz after watching both drop back to 880rpm and ~65C with 4.2.13. With 4.2.11, the sys fans settled at ~1170 rpm and the temps are 58C. This is after calibration and letting them run as usual overnight. I'll stay with this version of firmware until I see if there's betas to try out.
