mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
PapaBear1
Sep 19, 2010Apprentice
For those experiencing this problem, downgrading to 4.2.11 seems to work in most cases. However, those with WD 4K sector drives would be in a quandary as they need either release 12 or 13 for their drives.
