mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
lisster
Sep 19, 2010Aspirant
Over the last few days ive been keeping a closer eye on this problem.
With me the system runs fine for most of the day but EVERY day between 8pm and 10pm it doesnt go over 900 until it overheats or i do a calibrate.
It keeps doing this for about 30-40 min then it works fine till the next day.
This has been constant for the past 4 days, ill keep an eye on it if it does it all week.
PS: @papabear: other then 4k sector drives is there any negative effect going back to .11? speed wise and/or ext4 issues?
