mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp runnin...
mdgm-ntgr
Sep 19, 2010NETGEAR Employee Retired
You would lose the feature improvements and bug fixes since 4.2.11. 4.2.11 was the first firmware to have native EXT4 for the Pro (required a factory default - wipes all data, settings, everything).
See http://www.readynas.com/RAIDiator_x86_4_2_12_Notes and http://www.readynas.com/RAIDiator_x86_4_2_13_Notes
I expect if your partitions are already aligned for 4k sectors, things may work ok with 4k sector drives (I haven't tried the downgrade. I'd suggest backing up your data if you can, just in case something goes wrong). Of course on the old firmware if you replace a disk then the 4k sector alignment may get messed up perhaps leading to poor write performance.
